I bought a good running '93 K1100RS last May and have been bringing the bike back to its former stock self.
Photo day after purchase...
http://www.pbase.com/dwerbil/image/124642895
I discovered shortly after buying it that the bike has been lowered about a inch and a half. To bring the bike back to stock, I replaced the shorter rear mono shock with a stock one, and have changed the 17" five spoke rear rim back to a 18" three spoke. That change allows me to now get the bike on its centerstand. Another bonus...the speedometer and odometer now are just about spot-on in their accuracy.
The main issue left now is the front suspension and bringing it back to stock. I assume it's lowered a bit. The fork tubes appear to be at the top of the triple tree, so there's no lowering there. The next place I guess to look is the length of the fork springs. Does anyone here have the stock length the springs should measure? I'm guessing if the front has been lowered that its been done with shorter springs.
Thanks for any help.
Randy
Bringing a K1100RS back to stock
Re: Bringing a K1100RS back to stock
Hi Randy, glad to see you here. Nothing I hate more than a perfectly good motorcycle getting lowered to substitute a little rider training & dedication Thats bound to stir up some debate...
Since you can't stretch the springs...at least not very easily...why not just getcherself a new set of stock springs?
Cogito Ergo Moto
- Moderator
That's just it Veg, I don't know what the stock length is. When I open up the forks, I'll want to have that info to check what's there.Since you can't stretch the springs...at least not very easily...why not just getcherself a new set of stock springs?
- Moderator
Matt, this forum looks like it's going to be a great one. Thanks for all your efforts.Hi Randy, glad to see you here. Nothing I hate more than a perfectly good motorcycle getting lowered to substitute a little rider training & dedication Thats bound to stir up some debate...
I found out the bike had been lowered when I was installing a Ebay centerstand. It was impossible to get the bike on its centerstand. Now I know why it didn't come with one. At least now with the now stock rear mono shock and stock rim, I can fanagle it up on the centerstand. Correcting the fork springs would most likely help it even more.
I think I see your point...you're not sure if the front is at the stock height or not...might be, but might not be...right?
Cogito Ergo Moto
Check the sag. If it's not sitting too far past full extension, then the springs aren't any shorter. Maybe someone here can tell you what their non-rider sag is right now. I only have a K75, and it might be different. If the non-rider sag is over 1-1/2" or so, then it could just be ol sacked springs, but it's probably shorter springs or reduced preload.
With (average weight) rider SHOULD be around 30mm or so.
Check the front tire too. Some people put lower profile tires on to drop the bike some.
welcome back ! do you still have the K75RS
- George Ryals
If the front has been lowered as much as the rear was, riding the bike with the taller rear shock may get exciting (tank slapper). Especially getting on the brakes on a down hill run.
Smile it's contagious!
'85 R80RT wreck for parts
Hey Richard!
That is still an unfinished project in my garage. I REALLY need to do something about that.
