Airbox surprise.
Re: Airbox surprise.
If I see spiders first, I like to marvel at their abilities, their shape and other unique features. I used to feed a golden orb spider bits of salami from a pizza!
If they see me first !@#$% *##@!
Deleted User 287
Post by Deleted User 287 »
ME 109 wrote:If I see spiders first, I like to marvel at their abilities, their shape and other unique features. I used to feed a golden orb spider bits of salami from a pizza!
I've never met a spider that will eat anything that is not moving.
How fast does salmonella move?
SteveD wrote:
justoneoftheguys wrote:How fast does salmonella move?
I've heard of a fish called Wanda, but not a salmon, Ella. Ella, sounds like a fast mover tho.
Yeah, I'm told it gets things movin' when it wants to come out!
barndeadr80
Post by barndeadr80 »
What I found was a air filter with a nasty hole in it. After the long rest in the barn and early in the rehab, I had pulled the plugs, squirted some oil down the holes and was turning the engine using the rear wheel. I thought about the air filter, which had once been a chosen place for a mouse to store dog food long ago. I looked in there and found that a mouse had eaten a hole through the filter. Pulling the carbs revealed that by turning the engine it had sucked dirt, a mouse's nest and filter residue down the tubes to the carbs. It was a lucky time to have stopped turning the engine to check the filter.
Jean
Post by Jean »
Which accounts for your moniker: BARN DEAD R80, I presume?
It least it wasn't a LIVE hornet nest...
Post by Chuey »
justoneoftheguys wrote:No natural predators, that would be a problem.
Now if you were to have a good sized volcano erupt...
I'm noticing a theme here, Rob. First, the Yellowstone earthquake comment and now a volcano in Hawaii. OK, if we blame some nature program, maybe we should suggest that you watch some trashy TV. Some comedies, maybe. :)
At least something a bit more pastoral.
Deleted User 287
Chuey wrote: I'm noticing a theme here, Rob. First, the Yellowstone earthquake comment and now a volcano in Hawaii. OK, if we blame some nature program, maybe we should suggest that you watch some trashy TV. Some comedies, maybe. :)
I've been streaming Green Acres here at work, late at night. Better?
And from what I have seen (I'm no vulcanologist) Hawaii is not the explosive kind, just oozes. Which won't help with the intruders.
