Hello all, I have 3 transmissions apart, waiting to rebuild. Two of them have output shafts that DO NOT have the circlip groove. A friend, who is a very experience machinist and a longtime airhead owner, offered to cut the grooves for me. He has a full machine shop at his house. Some of you may know him- Carl Kultti.
He's never done this particular task before, but didn't think it would be a problem. Well, here's the problem. He is unable to cut into the shaft- using high speed steel cutters, and now a carbide cutter. The shaft seems to be too hard for these tools.
I'm certain folks here have done this or had it done. Can any one tell me what was used to machine that groove in the shaft?
Thanks in advance,
Don
How to cut the snap ring groove in the tranny ouput shaft?
'83 R80ST
'92 R100GS
'04 R1150RTP
garage full of airhead parts...
'92 R100GS
'04 R1150RTP
Re: How to cut the snap ring groove in the tranny ouput shaf
So, probably not a cold chisel, huh?
It's very difficult to imagine a carbide bit not working, but, certainly a diamond slotting wheel would work.
The failed attempts have probably work hardened the shaft making it difficult cut the groove. Good luck. Good quality carbide should have done it.
cut the snap ring groove in the tranny ouput shaft??
Hi again, I'm not a machinist, and know little about metallurgy, so maybe someone could explain "work hardened"? I think Carl attempted to cut the groove, but quickly stopped when the cutting tool was making no progress. Does anyone know if those shafts are hardened some special way?
Don
Don
'83 R80ST
'92 R100GS
'04 R1150RTP
'92 R100GS
'04 R1150RTP
Several articles on the web about this - Anton Largiader's and Gunsmoke's:
http://www.gunsmoke.com/motorcycling/r1 ... index.html
Snowbum mentions using a carbide tool. If the shaft cannot be cut on now, maybe just buy a new shaft with the groove already cut.
I repeat: if you can't cut it, grind it.
Diamond slotting wheel in a die-grinder mounted in the tool-holder location of the lathe. Mount the grinder so the wheel counter-rotates against the rotation of the shaft. This will probably require grinding from the opposite side of that from which you normally cut.
It could be cut with a surface grinder. A friend of mine has an attachment that allows an item to come in perpendicular to the grinder and rotate, the disk would then be lowered to cut a groove into the shaft. Or attach a grinder to the tool post of a lathe and bring the rotating disc into the work.
1974 R90/6 built 9/73
1987 BMW K75S
1994 BMW R1100RS
1964 T100SR Triumph
1986 Honda XL600R
1987 BMW K75S
1994 BMW R1100RS
1964 T100SR Triumph
1986 Honda XL600R
Grinding a groove that shallow and narrow with clean straight sides and bottom would be difficult. I have seen circlips climb out of rounded ground grooves.
Deleted User 287
Dremel along with a HEALTHY dose of robert's advice.
(What can I say, I trust & respect Bob.)
