According to the Valvoline specs the "increased" zinc-phosphorus % for the 20W-50 is 0.112/0.103, see more here: http://www.valvoline.com/pdf/4-Stroke_M ... le_Oil.pdfGarnet wrote:The 76 brand 4T Motorcycle oil I used to sell went from a ZDDP content of 0.138% down to around 0.098% when they added "SJ" to the label evan though they still has "SG" on the label as well.Tim Shepherd wrote: Valvoline makes a 20W-50 oil specifically for 4-stroke motorcycles. It has "JASO MA API SF/SG/SJ" on the label, I believe one of these indicates it's got the ZDDP for flat tappet engines. Can anyone confirm this?
It is too bad it is so hard to find these specs. ConcoPhillips has allways been good about posting info to us but other companies, Shell for example, feel it unneccesary to do so.
Warning.. another OIL (additive) thread.
Re: Warning.. another OIL (additive) thread.
Last edited by Deleted User 62 on Mon Sep 27, 2010 8:52 pm, edited 1 time in total.
On the link you posted it shows a Zinc content of 0.112% which is a tich low, but much better than most automotive oils.
Another good spec that they show is a Flash Point of 230C, which is important for an aircooled engine. A lot of new auto and some new diesel oils are as low as 200C. The lower the flash piont the sooner oil consumption begins.
OK THANKS FOR SOME ANSWERS ...but still not clear on the wt. i have never used a 20-50 wt in any thing i own so val 20-50 is a good choice i see ..... now the trans and shaft drive can take a full syn Gl-85-90 wt.
SO CAL. WE RIDE ALL YEAR LONG
Yes as long as it is Valvoline Motorcycle oil.
Yes on the 80/90 synthetic gear oils.
