Center Stand sic
Center Stand sic
1984 R100S
So do you guys routinely change bushings AND bolts. Do tell! :shock:
Re: Center Stand sic
If the bike's new to me, it's one of the things I do.
I keep the bolts tight, and annually remove the bushes, inspect regrease/reinstall etc...replace as necessary.
If the side stand itself is worn from contacting the frame mount, new bolts and bushes will not be a fix.
dougie
Post by dougie »
SteveD wrote:I keep the bolts tight, and annually remove the bushes, inspect regrease/reinstall etc...replace as necessary.
What SteveD said. Worth doing.
What I said. Not worth a pinch a s**t as far as a centre stand is concerned. :mrgreen:
