Your ride was not a problem Souljer, near full oil increases the chance of other issues causing the light to come on.
What oil are you using? 20/50 at least hopefully. That's good for 115 F and no oil light.
The flickering light is more an indication of a starved oil circuit. That could be on the pick up side of the oil pump, or the downstream side.
Monitoring is the next step before pulling anything apart.
There are other causes like incorrect pressure sender unit?
I've had a flickering oil light.........................
