Jaycar LED lights when fuse is blown.
2valve wrote:Hi to all, is the headlight globe that you'd like to change is it fitted to the R90/6(S) ? , if so theres no need to remove the fairing at all maybe you might have to loosen the two bolts that hold the rod arms on so you can align up the headlight with the centre of the S /faring. Before you start find a very large soft towel and place it directly under the headlight that way you cannot damage your paint work if you let slip the headlight onto the guard , please dont ask me why i know this ! I use a large screwdriver (carefully not to scratch the paintwork ) to pop open one of the sides of the headlight shell , headlight will then be off it mounts as such , lift up the headlight itself to clear the top anchor point and there you go , sounds easy hey ! takes a bit of jiggling to clear everything. Works for me this way for a very long time.
