Why Does Rob's R65 Run Rough?
Re: Why Does Rob's R65 Run Rough?
Post by Garnet »
Chuey wrote:Rob, what did the dealer say?
The Electrolux dealer said he sucked. :lol:
Jean
Re: x-over pipes
Post by Jean »
Any vac. shop probably has some "junk" wands lying about. Sometimes I get them free, last time I paid $2 each for 4.
the latches are broken, or they are dented where they fit together. Neither of these faults affect then for what we need to do.
I happen to know Electrolux pipes are EXACTLY the right size. They were made in Italy. METRIC.
Deleted User 62
Post by Deleted User 62 »
justoneoftheguys wrote: I can't order diaphragms for a couple more weeks, yet.
Rob, check out http://www.eubmw.com for carb rebuild kits. Cheapest price I have found on the web, and free shipping too!
Jean
Re: what size carbs??
Post by Jean »
What are the part numbers on your carbs, ROB. There is a shop here that sells parts for old Brit cars and he might have a pile of Stromberg diaphragms...
I think they are 32mm, but it's been a while since I worked on an R65...and since you got a replacement engine...??
Deleted User 287
Post by Deleted User 287 »
Jean wrote:What are the part numbers on your carbs, ROB. There is a shop here that sells parts for old Brit cars and he might have a pile of Stromberg diaphragms...
64/32/204 & 203
I don't know if there were any changes made to the carbs when they introduced the '81 Nikasil engine with the larger [intake only?] valved heads. If there was, I might need to consider changing needle position, too.
Jean
Re: Stromberg CD150 carbs
Post by Jean »
In case anyone need to go looking for them:
Austin Healey
Square Body Sprite (All Years)
Bugeye Sprite (All Years)
MG
Midget (1975-1980)
Triumph
GT6 (1966-1973)
Spitfire (1962-1980)
robtg
Post by robtg »
Jean wrote:In case anyone need to go looking for them:
Austin Healey
MG
Midget (1975-1980)
Triumph
GT6 (1966-1973)
Bugeye Sprite (All Years) and at least early square bodys had SU carbs.
Deleted User 287
justoneoftheguys wrote: My carbs are 64/32/203 & 204 (from a '79)
Well, checking RealOEM, I see that they did, indeed, change carbs.
For '81-'84 they were 64/32/335 & 336
For the mono-shock R65's they were 64/32/361 & 362.
Does anyone know what, exactly the suffix means?
edit: I did find this site: http://www.bingpower.com/english/servic ... etter.html , but it doesn't show my 203/204 carbs!
enigmaT120
Post by enigmaT120 »
Rob, do you have the Bing manual? I wouldn't worry too much about the specific carb model numbers, but try to make sure you have all the correct jets and needle settings for that motor. I don't have my book with me or I would post them, let me know if you need them. When I discovered that one of my original carbs was defective I bought a pair from e-bay from an LS. It came with different jets than my original carb, but I just put the jets from my old carb in it and it works great.
Ed Miller
'81 R65
'70 Bonneville
Falls City, OR
Deleted User 287
No Ed, I don't have the manual. I suspect I may need different jets for the larger valves.
