gasket removal
michael
gasket removal
Post by michael »
Any one know a trick for removing gasket material?
Re: gasket removal
On aluminum I use the spray chemical remover.
dougie
Re: gasket removal
Post by dougie »
And I use laminate countertop samples such as Arborite for scrapers.
michael
Re: gasket removal
Post by michael »
Thanks for all the advice. I found a product at Auto Zone: Permatex Gasket Sealant Remover that really helped. It has a little brush on the end of a spray can that makes it easy to put the stuff only where you want it and it works pretty well.
Re: gasket removal
Wilkinson Sword.
Curt Henry
Re: gasket removal
Post by Curt Henry »
Loctite sells an aerosol gasket remover that works very well, just give it time to dissolve the adhesive.
Don't scrap and gouge the metal, let the gasket remover do it's work.
