Page 2 of 2
Re: Hey Claude
Posted: Sun Aug 05, 2018 6:30 pm
by Wobbly
But, the original cam chain tensioners were also known to be slack. When you get your new tensioner spring you'll see that the latest model spring is much stronger.
Re: Hey Claude
Posted: Sun Aug 05, 2018 9:12 pm
Wobbly wrote: Sun Aug 05, 2018 6:30 pm But, the original cam chain tensioners were also known to be slack. When you get your new tensioner spring you'll see that the latest model spring is much stronger.
I think my tensioner still has the stock spring. I do believe tho that the oil behind the piston is the real player in resisting the pulses of the chain. It acts like a damper.
I've thought for a while that maybe my piston is longer, modified/experiment for racing to restrict how far the chain can push out.
I dunno, but I know I couldn't push the piston all the way into the bore, like I can with my old front bearing carrier.
The front was all buttoned up before finding this difference. I'll know for sure next time I'm in there.
