Page 2 of 5
Re: I just removed my first valve spring!
Posted: Fri Aug 19, 2011 7:55 pm
by vanzen
I would not think that the orientation of the spring matters ...
Certainly less so than verifying it's compression rate ...
Posted: Fri Aug 19, 2011 8:25 pm
by Deleted User 287
vanzen@rockerboxer.com wrote:I would not think that the orientation of the spring matters ...
Other than possibly suffering some damage in the crash, the springs were relatively brand new, having been replaced by Bob Grauer when he refurbished the heads in the fall of 2006. The crash was two years later, in 2008.
In fact Bob replaced valves, seats, springs and collets. Everything except the top and bottom spring plates, if I remember correctly.
I really feel bad about destroying half of Bob's artwork with my inattentiveness.
My finger hurts sometimes, too.
lapping valves ...
Posted: Fri Aug 19, 2011 9:43 pm
by vanzen
Don't feel bad, Rob ... Sh!t happens, move forward.
Same valve, same head & seat, but different spring ?
or different valve on the seat ?
Re: lapping valves ...
Posted: Fri Aug 19, 2011 10:32 pm
by Deleted User 287
I am going to install the springs (and possibly collets, tops and bottoms - depending on rust) from Bob G's work onto my new used engine that has rusted internals.
The old engine was a '80, the new engine is a '81.
The differences are Nikasil cylinders and different sized valves, so I
have to keep the valves that are on the marginal engine.
I have already rejetted the Bings to '81 spec., and pretty successfully (for a first time), if I dare say it. My run to Columbus, OH and back last May showed normal power and fuel consumption.
The part #s on everything except the valves themselves were unchanged from '78 - '84 on the Type 248 engine:
http://www.realoem.com/bmw/partxref.do? ... series=248
You may have missed my original thread on this, started last Sunday afternoon:
http://www.boxerworks.com/forum2/viewto ... f=1&t=2924
Posted: Fri Aug 19, 2011 10:45 pm
Rob, I look forward to some 'out there and riding' posts from you.
It's been a while man!
Posted: Fri Aug 19, 2011 11:07 pm
by Deleted User 287
ME 109 wrote:Rob, I look forward to some 'out there and riding' posts from you.
My plates expire 15 Oct....
Posted: Fri Aug 19, 2011 11:17 pm
by vanzen
Hmmm ... mine, too.
Posted: Sat Aug 20, 2011 1:44 pm
by Jean
You will surely have this beast back together by Oct 15. Hopefully by Sept 1...
It's time to start another post: "I just got all the valve springs re-installed" !
Posted: Sat Aug 20, 2011 2:28 pm
by Deleted User 287
Jean wrote:You will surely have this beast back together by Oct 15. Hopefully by Sept 1...
And I'm betting it is NOT a good idea to reuse head gaskets.
I neglected to include them in my order for o-rings - not that I can afford to be throwing another $33 +shipping at this project while unemployed.
Posted: Sat Aug 20, 2011 2:53 pm
by dougie
justoneoftheguys wrote:And I'm betting it is NOT a good idea to reuse head gaskets.
Not necessarily recommending this, but I used it once on an air-cooled engine and it worked.
I guess it would depend on how good/bad you gaskets are.
http://www.permatex.com/products/Automo ... ealant.htm
