Since this was my first time, I began with my old L-S head that got torn up in the crash. The exhaust spring looks rust-free, so far.
My first question - do these springs have a top/bottom orientation of which I should be keeping track?
I had to compress the spring completely before the collets would come loose. (I will assume for now that that is normal, seeings how there is oil holding them together).
And the upper spring plate (at least on this valve) has rust on it from pulling duty as bunny cage protector.
I will clean the spring(s) with acetone (I have some on hand) and examine them closely in the daylight with magnification.
I won't use the acetone until I hear back from you guys, though.
I have only done the exhaust valve as I am typing this, and while the valve rotates freely and moves in and out through some portion of it's range, it doesn't seem to want to slide right out.
Either this is normal, or it is a result of the impact.
It was on the exhaust stroke when the crash occured (see 2nd picture).
Thanks for all your help & encouragement, folks.
If the final drive resealing goes this easy, I'll be in like flint!
