Yeah , good point .I don't have a GPS so really have no idea of my real speed .ME 109 wrote:I've only taken notice about 5000 times. I think it's 3800 @ 100k.Sibbo wrote:
What do you spin at 100 km ?
Then there is also the inaccuracy of the speedo to consider. Mine is about 10 k optimistic.
Red line ?
- Sibbo
Re: Red line ?
The Grateful Dead
The Grateful Dead
Re: Red line ?
I get near red line nearly every time I ride. Don't want to get a cylinder bore ridge
Re: Red line ?
The R65 loves to rev...so it does. It see the red line many times on every ride,and often hits 8,000rpm if I forget to watch the tacho...
- Sibbo
Re: Red line ?
OK , I'm feeling better ... I thought I was being a bit cruel .
The Grateful Dead
The Grateful Dead
- Steve in Golden
Re: Red line ?
So if I regularly rev the shit out of my engine I won't have a case of the dreaded cylinder bore ridges?Zombie Master wrote:I get near red line nearly every time I ride. Don't want to get a cylinder bore ridge
Re: Red line ?
I know a guy who has his heads done by a guy who uses skinnier valve stems. I'm thinking it's 8mm. Anyway, he says it revs up much more readily.Garnet wrote:I don't have a functioning tach on my conversion or my /5 but both have the same 72 R75 engines. I will rev them in lower gears till they run out of breath which is probably around 6500ish RPMs and sometimes beyond.
Stock valve train will take 7500ish before it begins to float. With a 336 cam the engine is making good power above 7000 so it is worthwhile lightening the valve train to make it safe up to 8000.
Re: Red line ?
Unlike coitus where we never ever go all the way in, the piston rings need to go as far in as possible to avoid creating an area that is unused, therefore creating a ridge. This could cause a catastrophic failure if that point is finally reached after a long period of operation. So I recommend regular trips to redline along with the production of large stools.Steve in Golden wrote:So if I regularly rev the shit out of my engine I won't have a case of the dreaded cylinder bore ridges?Zombie Master wrote:I get near red line nearly every time I ride. Don't want to get a cylinder bore ridge
- Steve in Golden
Re: Red line ?
I'm sorry I asked.Zombie Master wrote:Unlike coitus where we never ever go all the way in, the piston rings need to go as far in as possible to avoid creating an area that is unused, therefore creating a ridge. This could cause a catastrophic failure if that point is finally reached after a long period of operation. So I recommend regular trips to redline along with the production of large stools.Steve in Golden wrote:So if I regularly rev the shit out of my engine I won't have a case of the dreaded cylinder bore ridges?Zombie Master wrote:I get near red line nearly every time I ride. Don't want to get a cylinder bore ridge
You feeling OK ZM?
Re: Red line ?
Sounds like a real large stool to me.Steve in Golden wrote:I'm sorry I asked.Zombie Master wrote:So I recommend regular trips to redline along with the production of large stools.
You feeling OK ZM?
- boxertwinjeff
Re: Red line ?
I tend to rev my engine hard throughout the gears, though not to the point of redlining it,
I thought redlining would be detrimental to the engine yes?
1973 R1000/5 LWB
1976 R90S Silver Smoke
