fork oil options?
Re: fork oil options?
Answer to my e-mail from Bel-Ray -
"Doug,
Thanks for writing in.
Bel-Ray High Performance Fork Oils are fully compatible with each other
and can be mixed to get different weights. To get a 7W from a mix of 5w
and 10W you mix 15% 5W with 85% 10W.
Thanks for using Bel-Ray Performance Products
Regards,
SirTech "
So the concept is good, but the math is tricky.
DanielMc
Post by DanielMc »
dougie wrote:Answer to my e-mail from Bel-Ray -
"Doug,
Regards,
SirTech "
At least that solves half the problem - using Robtg's link I was able to get 7.5w with around a 40/60 split, broadly in line with Bel-Ray technical advice that you need more "heavy" and less "light" in the mix if you want to get between the two viscisities.
Very useful stuff...
I bought some inexpensive 7wt off the shelf at a local shop last fall. I'll find the bottle and post the brand.
Funny...I take the Bel-Ray numbers and plug them into the link given previously, and I get a 9wt oil. Oh, well...
BoxerTwin
Post by BoxerTwin »
thanks for the answers. I wasn't sure if the ones that Haynes was stating were really the only options or not. I'll pick up some 7.5 and try it out.
Buy land. They ain't making any more of the stuff.
Will Rogers
1977 R100/7 dressed up like a R100s
