Page 5 of 6
Re: R100RS fairing - any replicas?
Posted: Mon Sep 12, 2011 6:11 pm
by vanzen
justoneoftheguys wrote:
I shoot for the Golden Rule most of the time, but sometimes I miss the mark...
Even in the absence of defining that "golden rule" for himself – Rob said "sometimes".
Conversely, I will always say just what I am thinking –
Re: R100RS fairing - Any Downers?
Posted: Mon Sep 12, 2011 6:15 pm
by Deleted User 287
Posted: Mon Sep 12, 2011 6:17 pm
by Deleted User 287
Is that a put-down?
Help me out here, MS...
Posted: Mon Sep 12, 2011 11:33 pm
by Deleted User 62
dougie wrote:Simple.
One rule.
Don't be an asshole.
Dang... really? ...well, that's it, I'm outta here!
Posted: Mon Sep 12, 2011 11:46 pm
Is that a put-down?
Nope. It was just to accentuate the difference between your "sometimes," and his "always." You "sometimes" fail to meet the standards of the Golden Rule. He "always" says whatever he is thinking. To clarify, you sometimes fail to consider others, he never does. Doesn't mean he's being an asshole, just means he isn't filtering, while you are.
I don't know if I really believe him: that he always says whatever is on his mind without filtering, but that's what his statement meant.
Posted: Mon Sep 12, 2011 11:53 pm
Tim Shepherd wrote:dougie wrote:Simple.
One rule.
Sorry, you can't leave just because of that. Leaving just cause you're an asshole would be being . . . an asshole.
And, that's against the rule.
Posted: Tue Sep 13, 2011 12:09 am
by twist
Posted: Tue Sep 13, 2011 5:06 am
by R85/8
vanzen@rockerboxer.com wrote:R85/8 wrote:...I was after information, not insults.
No personal offense was intended, R85/8
OK, sorted
As far as making your own parts/modifications rather than just bolting on bits, I always prefer a make it yourself solution to a bought one. My username might give a hint as to my ultimate intentions
Anyhow, I've come to the conclusion that a new replica is going to be almost impossible to find. In the meantime I've bought most of the lower fairing on eBay, so now I have one and a half fairings, and I'm bidding on a brand new top side. I'm just going to keep buying the bits until I have enough to build a good one. Just in case I've ordered some f/g cloth for a mould, so I may yet end up with a homemade replica if I can't get enough good bits.
Lovely fairing - but only available to the USA.
I have no objection to the cost of the fairing, but after seeing the fractures on the "good" one I have just bought, I'm dubious about the strength of 20-30 year old plastic. Once I have got a few more fairing parts I can come to a more definite conclusion.
One of the things I'm considering is applying a layer of carbon fibre cloth to inside of the existing fairing to reinforce it. Then the brittleness won't matter. I'm pretty sure epoxy will do the job. I'll do a test piece on the worst part once I have enough bits to spare.
Posted: Tue Sep 13, 2011 5:56 am
by Deleted User 72
You will find carbon fiber
very difficult to work with. Most of the pros don't try open molding with it. It is too stiff to "lay down" on an open mold, and won't go around corners, either male or female, without a second mold or vacuum bagging to hold it in place during cure.
If I were to repair cracked pieces, I would laminate light cloth both inside and outside the crack area, after tapering both sides' laminate (10:1) towards the crack. The actual crack would be the "valley" between two hills of the original laminate.
Fill the valley with laminated glass fiber, sand off the peaks, putty, sand, repeat,...paint. I would also consider re-inforcing large areas, if not the whole piece, with a light cloth laminate on the unseen inside.
Posted: Tue Sep 13, 2011 7:28 am
by R85/8
For the reinforcement idea, I was planning on using a 200gsm twill laid on the inside of the existing fairing parts. That way if it didn't conform well enough, I could just cut darts in it rather than get too fancy - it's going to be hidden by paint any way. It also means that the original surface of the fairing remains undisturbed.
I would be doing this to undamaged fairing parts as a preventative measure rather than a repair. However, once I have enough bits to sacrifice one, I'll experiment with repairs on the cracked bits - maybe a heat gun and some plastic welding rod will do the trick.
Anyone know what exactly the fairing material is? It looks like a thermoplastic to me, but I didn't pay attention at the time they were released because I didn't like fairings - now I'm older and gone soft...
As far as making a whole fairing from c/f, I'd expect that to throw up a few challenges.
