rear brake- light not activating
Posted: Sun Feb 19, 2017 10:48 pm
by antocas
nearly ready to get my refurbished r100rs on the road again,,but the brake light doesn't come on when the rear brake is used ,,the front brake lights up fine,,
I cant figure out how the Norris switch is removed,,does it have two screws holding it?
could this be the problem
look forward to some advice and inspiration
regards tony
Re: rear brake- light not activating
Posted: Sun Feb 19, 2017 11:15 pm
Spray the switch with electrical cleaner...jiggle it...spray it again. They get gunked up and usually just need a clean.
Boronia, Vic, Oz?
Posted: Mon Feb 20, 2017 12:51 am
Two screws under the rubber cap on top of the switch.
Check the brake pedal is contacting the front of the switch.
Check you have power to the switch. Check you have power to the brake light bulb socket, when activating the brake pedal.
Posted: Mon Feb 20, 2017 10:49 pm
by antocas
I'm in boronia vic aus
Posted: Tue Feb 21, 2017 11:45 am
by montmil
Had this issue on my 1978 R100S. The rear brake light would work only occasionally. Checked proper operation and brake pedal contact, power to the tail lamp, bulb function. Hosed it with electronic parts cleaner spray, burned incense, chanted...
Bought new switch. It's all good. :D
Posted: Wed Feb 22, 2017 2:30 am
by antocas
thanks blokes ,ive got that little sucker sorted,twas the Norris switch-loose connection,,a bugger to get at ,but I'm nearly finished my bike now
thanks all
Posted: Wed Feb 22, 2017 3:06 am
antocas wrote: Wed Feb 22, 2017 2:30 am thanks blokes ,ive got that little sucker sorted,twas the Norris switch-loose connection,,a bugger to get at ,but I'm nearly finished my bike now
thanks all
Pix or it didn't happen! ;) Oz Boxerworkers are organising a ride first weekend in May, to a pub towards Griffith. We usually do mountain rides, but this one is close to a couple of blokes that live out that way, for a change. If you're interested, I can supply details.
I'm in Croydon.
