Stuck ignition switch
Posted: Wed Sep 06, 2017 2:43 am
I've lifted this from BMBikes forum. It's an excellent article on how to loosen stuck lock wafers in the ignition switch. Hopefully no-one will need this info.
http://www.bmbikes.org.uk/Forum/viewtop ... 37#p174637
Re: Stuck ignition switch
Posted: Tue Sep 12, 2017 7:22 pm
by The Veg
But ignore the first reponse- do NOT use WD40 in a lock. It may help short-term but as it is mildly corrosive and can leave residues, it's not good long-term.
Posted: Thu Sep 14, 2017 4:53 pm
by George Ryals
A QUESTION OF LUBRICATION
Myth: WD-40® Multi-Use Product is not really a lubricant.
Fact: While the “W-D” in WD-40® stands for Water Displacement, WD-40® Multi-Use Product is a unique, special blend of lubricants. The product’s formulation also contains anti-corrosion agents and ingredients for penetration, water displacement and soil removal.
Posted: Thu Sep 14, 2017 7:10 pm
by robert
WD-40 is great for drilling,taping,machining, aluminum.
It doesn't leave a mess or stain like some other cutting and taping fluids.
If you need lube use Triflow with teflon.
Posted: Fri Sep 15, 2017 9:55 am
by dougie
robert wrote: Thu Sep 14, 2017 7:10 pm WD-40 is great for drilling,taping,machining, aluminum.
+1
Posted: Sat Sep 16, 2017 10:53 am
by The Veg
Corporate propaganda.
