R80 Electrical Issue
Riverman0000
Post by Riverman0000 »
Hi all
First time poster here.
I’ve recently purchased a 1985 BMW R80. Indicators, horn and rear brake light were working, however they stopped suddenly. The indicator did flicker fast before packing up. The strange thing is that they work when the high beam flash is depressed. Relay switch is working when tested, Fuses are intact. Any possible suggestions would be appreciated. Thanks
Re: R80 Electrical Issue
Welcommen. :D
Have you got a wiring diagram :?:
Weird things are often earth issues.
r67boxer
Post by r67boxer »
Riverman0000 wrote: Tue Feb 06, 2024 7:48 pm Hi all
I had a similar issue with my '78 R80. It turned out to be a bad ground to the coil bracket.
Kevin
Is that a monoshock or a twin shock bike? I only ask because 1985 is just about on the cusp of the changeover between the two and the wiring is very different...
