I have a 1978 r100/7 and was checking the rear brake lights and found that the front brake lever when applied was not turning on the brake light. I checked the connections on the Master brake cylinder and found the connection weak so I replaced connectors. The brake light now works but I have to apply very heavy pressure to the hand brake lever. should the switch work with low pressure? Does anyone have an idea of what the PSI should be? I can't find any information from websites like AScycles.com or Hucky's Spare Parts. Should I just replace switch at $34.95? Any advice is appreciated.
Thanks,
Pressure swich sensitivity
Mase
Canby,Oregon
1978 R100/7
2002 R1150R
1981 Yamaha xs650 Special (project bike becoming a cafe racer)
Canby,Oregon
1978 R100/7
2002 R1150R
Re: Pressure swich sensitivity
VW Beetles and 60s Volvos used the same switch. I'll find a part number that you can cross over at your local auto parts store tomorrow.
Yes - just replace the switch. It may be gummed up with old brake fluid.
Wow! $34.75 at Hucky's!
Fortunately, if you are not too young, it will be the last one you will need to buy for the bike.
Much mo betta:
http://www.autopartswarehouse.com/searc ... ght+Switch
Much mo betta:
Standard Ignition (Blue Streak) # SLS33 is the one you need. You should be able to cross that number to Echlin or Neihoff as Stnadard owns those companies as well. We sell that switch of about $11 in Canada.
Thanks for all the input. After you advice on the Volvo I looked up the switch on IPDusa.com a Volvo distributor in Portland, OR and found it for $5.50!
Mase
Canby,Oregon
1978 R100/7
2002 R1150R
Canby,Oregon
1978 R100/7
2002 R1150R
- Slashsevenpig
I've got a 1977 R100/7, and I found out from somewhere (can't remember) years ago that bleeding the front brake at least once every riding season keeps the brake switch functioning. Might be due to internal condensation causing a formation of crud. Fortunately, it's a relatively easy task, even with the switch being located under the fuel tank (on my '77).Yes - just replace the switch. It may be gummed up with old brake fluid.
Garnet, thanks for the info! The high price of the switch from the dealer is what motivated me to do yearly brake bleeds.VW Beetles and 60s Volvos used the same switch. I'll find a part number that you can cross over at your local auto parts store tomorrow.
Yeah, I'll admit it's been a few years since the brake bleed which was part of this winters bike maintenance. So wise advice taken.
Mase
Mase
Mase
Canby,Oregon
1978 R100/7
2002 R1150R
Canby,Oregon
1978 R100/7
2002 R1150R
