Removing the carbon build-up in side the combustion chamber
DonW
Post by DonW »
Hi- have 4 heads on my bench and am wondering the best way to "de-carbon" them. Have soaked in liquid in the past and then scraped (plastic scraper) and water blasted, but it's a chore. Any advice on a quick, painless, and easy way to do this (does anything like that ever exist??)
Lazy old Don
'83 R80ST
'92 R100GS
'04 R1150RTP
Re: Removing the carbon build-up in side the combustion cham
As long as all the loose and protruding chunks are gone, the remainder won't make any functional difference.
Any shop that machines heads has some way of getting every bit off. Give them a call. Maybe it will be so cheap as to make it worth farming out.
Curt Henry
Post by Curt Henry »
Simple Green full strength soaked over night will loosen the carbon to where you can wipe it off with a rag and Scotch Brite.
dwerbil
Moderator
Post by dwerbil »
Don, bring those heads over to my garage. I've got a cabinet sand blaster. A six pack should
due us during the process. :P
But yeah, like Curt Henry said...I've had good luck with hosing down with Simple Green to scrub clean the next morning.
If you do sand blast them, blast them clean at the local self serve car wash.
Click for pics
Randy in Round Rock
DonW
Post by DonW »
Oh yeah, now I remember using a Simple green soak in the past. Seemed a bit harder than just wiping them off after, but I'll get to it.
And, I think I ran through the dishwasher (wife was waaaayyyyy out of town) after the scrub off...
Think it will make things any easier if I heat up the heads or Simple Green first?
Don
'83 R80ST
'92 R100GS
'04 R1150RTP
If you run them through the dishwasher (not a bad idea), DON'T use your dishwasher soap in there with them. It is very corrosive to raw aluminum.
dwerbil
Moderator
Post by dwerbil »
Major Softie wrote:If you run them through the dishwasher (not a bad idea), DON'T use your dishwasher soap in there with them. It is very corrosive to raw aluminum.
Hints from Heloise sez nada to any "Lemon Scented" dishwashing soap..."It'll stain the bullcrap out of aluminum wear".
(And I have the heads/pans to prove it.)
Click for pics
Randy in Round Rock
George Ryals
Post by George Ryals »
http://www.orisonmarketing.com/cleaners ... arbon.html
Somebody on Boxerworks posted this web site sometime in the past, hope it helps again.
