Kurt in S.A. wrote:Leak 1 - clean up the threads, new crush washer...don't tighten too much. Also, don't overfill.
Got it. Also, I think the front seal is leaking the oil from the drive shaft causing the overfill. At least on privious checks, the shaft was low on oil. I have not cleaned it up and checked it yet after this trip.
Kurt in S.A. wrote:Leak 2 and 9 and possibly 8 - either rear main seal or tranny input seal. Will need to pull the tranny to see what's leaking. What's on the "shelf" below the tranny? That would be the first thing to check.
There is oil on the shelf. It looks like this:
Kurt in S.A. wrote: Leaks 6 and 7 - either pushrod tube seals or oil switch. You should clean this area up real well and blow baby powder over the area. Then take a short ride and check for oil runs within say 5 miles...check again after 10-15 miles. That will let you know where it's coming from.
The push rod seals were replaced three years ago. I suppose they could have been bad. There is another active thread that talks about tightning them with a home made tool. Do you recommend that?
Lastly - San Antonio is right up the road from Austin. I hope you will come down for some portion of the Forum Rally here May 12 - 16
Thanks for the help.
Brad
