Dumb /5 cable question
Unclviny
Post by Unclviny »
There is a cable-retainer on the inside of the LH headlight Ear, what is it for? (all of my cables are routed to the right of the headlight).
Vince
1973-1/2 BMW R75/5 (LWB)
1971 Norton Commando
1952 Triumph TRW
1936 BMW R2
Frog
Re: Dumb /5 cable question
Post by Frog »
Usually the front brake cable goes there. It comes out of the control, across to that (left) side, down through the ear and back across to the right side of the fender.
Post by Deleted User 62 »
Yep, it's for the right brake cable. The OEM cables come with a grommet that mounts there.
Unclviny
Post by Unclviny »
Thanks
Vince
1952 Triumph TRW
1936 BMW R2
Frog
Post by Frog »
That said, you don't have to use it. As long as your cable runs smooth and does not bind, you don't have to follow the factory way.
Frog wrote:That said, you don't have to use it. As long as your cable runs smooth and does not bind, you don't have to follow the factory way.
On my currrent /5 and one of my prevoius ones there was no way I could get the cable across and through that clip. And they work just fine.
Frog
Post by Frog »
On my bike, the cable does reach there. I run a lower bar and use euro bar cables. The bars I use have a gently rise and are lower than most slash five euro bars. They may be from a slash two. They are just right for me.
On my stock headlight ears, I had that cable attachment point, but it took some force to get the grommet seated. Then I changed the headlight ears to some earlier versions, as I had to cut them down for my custom top triple clamp (I did not want to cut my stock ears). Those came with a ring for the attachment point, rather than an open clip. I have never bothered to run the cable through it. I just use a gentle zip tie to the grommet.
My biggest issue is that my cable rubs on my fender. I have seen some bikes with a chrome wire loop on the lower triple to keep it at bay, but that would not work with my current routing.
Unclviny
Post by Unclviny »
I want lower "Euro" bars but when I called Vech he wanted $228.95 for "correct Euro" bars and that aint gonna happen!.
I got aftermarket bars MADE IN THE U.S.A.! by Flanders, they are actually for the R90S and were $87.00, when I change bars I will see about routing the cable "properly" (and I'm going to install gray GranTurismo grips).
Vince
1952 Triumph TRW
1936 BMW R2
Frog
Post by Frog »
Unclviny wrote:I want lower "Euro" bars but when I called Vech he wanted $228.95 for "correct Euro" bars and that aint gonna happen!.
Vince
Wow, he must have been throwing in some Albert bar end mirrors with those.
Hucky's has reasonable prices on bars:
http://www.bmwhucky.com/007532.html
Mine are more like the Fehlings on that page, but are Magura. I think I bought them from Bob's a long time ago
