I was so excited, I rolled my 72 R75/5 into the shop and went to hook it up and there where no vacume ports.
So now I have to make some. My plan is to take a couple of short lengths of 3/16 steel brake line and tap the inside to take a 6/32 screw to block off when not in use. Then I need to drill the carbs to take the tubing. I have a ported set of carbs to uses as a sample for the drilling.
Now for the hard part, how do I fasten the steel tubes into the carb bodies?
I can think of three options:
1; Press fit by heating the carb body and freezing the tube.
2: Thread the outside of the tube and tapp the carb body and use a little dab of Loctite.
3: Good old JB Weld.
What do you'all think.
