? its back
Motorhead
? its back
Post by Motorhead »
well after a week of rideing a few laps around palos verdies where there are switch backs and roads with surface repairs I like to test my suspension all in all about 30 miles of ride and trips to work
...... I hoped the 5 hours of lapping my heads and checking the timeing was gona be the last of this puzzle and maybe if I rode it some the clear it maybe a hope for a higher PSI
today I have 120PSI on both cylinders, a little lower than when I finished the work last sunday
a few drops of oil didn't help and also it burns NO oil or loses oil or pushes out out the breather ??????? valves are stable
What if I have Ted Porter. Ed Corn... or other guru rebuild my heads and maybe a rebore and a set of new pistions with rings other than Hastings which I always trusted?????
Is the Californa gas killing my Bike?????
Re: ? its back
Edit: Oops, I mixed this up with the Krauser 4v bike.
Re: ? its back
I don't understand what the issue is...what does "?" in the subject mean?? Makes it kind of hard to know what's going on... Maybe it's just me...
George Ryals
Re: ? its back
Post by George Ryals »
Motorhead, 30 miles in one trip is barely enough to get the engine fully warmed up, forget seating the rings that fast. Put 2500 miles on it (in at least 50 mile incremente) then check the compression
Motorhead
Re: ? its back
Post by Motorhead »
the bike has 25,000 after a rebuild, the rebuild compression was 135 psi the bike ran strong and wondeful until last year I ride to sturgis and thats when I noticed the miles on the tank didn't last as I expected
I been blameing the Californa fuel for 4 years especally after the sturgis ride with my faithful BMW especally after use after the Sturgis ride when I got 35 MPG with the 37/11
I changed my rear drive for a better MPG Like my first BMW with 32/11 that got me 50 MPG. with the Texas run got me 25 MPG????????
so as I surched my problem I came to a 110 on riight and 95 left all other stuff like I said seems stable and right on time tappets and oil use is not suspect and stable
I spent 5 hours lapping the valves and after I put the heads back on and a trip around the hill seemed better
the trip around the hill is 30 miles and I actually ran the road 2X each time so 60 miles actually 2 times this last week
to work before the event so milage covered is ok the problem still exists
Motorhead
Re: ? its back
Post by Motorhead »
Oh to hear the bike it sounds normal and nothing other than a poor MPG says anything is wrong
Re: ? its back
What is your procedure for checking compression? And for the unread, what bike model/year do you have? Carb types?
Motorhead
Re: ? its back
Post by Motorhead »
the major part of year is a matching frame and motor case 1973 R75/5 after 87,000 the motor suffered a valve recession
I knew the history of this bike from the first owner...... I'm the 4th and last owner, the bike had Leaded fuel, then had first mix unleaded fuel, when I got it the fuel was 91 MBTE Unleaded , it seemed to like that gas..... then fuel changes again to 91 gasahol....
so when I rebuilt it I went to 1974 spec 900cc with stock bore used cylinders and matching pistions, with new rings and rebuilt R90 heads
Rings used were Hastings, heads rebuilt in National city
I used these rings before with my First BMW and had no trouble and the buyer that I sold to had no trouble, even when we we met again... after 4 years and over 40,000 miles after I built that one so as I had sucess before I retraced my build before I didn't account for a problem
the only thing diffrent now is I used heads I had rebuilt from Luftmeister........
I found last weekend the leaks are from the exhaust valve a sorta film burned on them like oil on a fry pan that coats the valve ruining the seal I lapped all valves
yesterday I checked my effort and I heard the same hiss that came last time as the cylinder comes to compression
Motorhead
Re: ? its back
Post by Motorhead »
Method is Mickuni carbs locked open and bike starter is used, if compression is in range( 125+) after 4 pumps of piston Grand if 5 to 6 Ok more is poor PSI range is 125 to 140 PSI full compression now is 120 after 5 pumps on top......
the guage is certified and I've use it for years as I'm a builder, I have a simler guage certified for leak down and again the leak is in the valves
