The seller had 30203J bearings.
A little while back I thought I'd finally understood my rear wheel pre load problems when it all came unstuck again.
The culprit to a great degree was a 30203J bearing.
The J version has a much larger shell radius where it sits up against its seat in the wheel, resulting in less 'seat' to support the bearing.
The height of the 30203J shell is about 1mm higher than a plain 30203. that may or may not be a problem.
I have also found a 30203A shell in my haunted house dead parts collection, but can't recall if it gave trouble.
So watch out for those J's. man.
30203J
