Tuning Advice
michael
Tuning Advice
Post by michael »
I have installed the rebuilt heads on my 78 R100/7 and put about 1k on it since then. Having trouble getting it to run right. Did the 1k valve adjust/check last night and all was well there. The left side plug was ok, a nice coffie color with just a slight bit of black fuzz. The left side has me pusseled. I don't have a pic but it looked almost brand new. Just an ever so slight coffie color on one side of the ceramic. Could this be that it is not firing at all.
Re: Tuning Advice
If it is not firing at all, it will shake badly, just pull a plug wire and you will see what happens.
I can't understand your post, as you say the left is good and then bad.
michael
Re: Tuning Advice
Post by michael »
Sorry Duane, I ment to say the right side has me pusseled.
Re: Tuning Advice
Ah, how I hate being pusseled.
First off, did you put brand new plugs in? That's an important piece to the pussle.
Re: Tuning Advice
Major, it may be a speech impedimemnt, go easy.
Re: Tuning Advice
ME 109 wrote:Major, it may be a speech impedimemnt, go easy.
Was your typo meant to be ironic? :lol:
michael
Re: Tuning Advice
Post by michael »
Yes, new spark plugs. Could it be my airhead fires on both cylinders at idle and not at speed? Also got out the dictionary:
PUZZLED Who would have ever thunk it!
vanzen
Re: Tuning Advice
Post by vanzen »
michael wrote:...The left side plug was ok, a nice coffie color with just a slight bit of black fuzz.
Black coffee or coffee with cream ?
michael wrote:...I don't have a pic but it looked almost brand new. Just an ever so slight coffie color on one side of the ceramic. Could this be that it is not firing at all.
Reading plugs ain't what it used to be with leaded gas.
Correctly burning unleaded does not color plugs the same.
Porcelain should be a very light brown almost white.
If the tips of the (center & side) electrodes are grey, the plug is firing.
jjwithers
Re: Tuning Advice
Post by jjwithers »
Timing? then sync carbs?
www.beemersandbits.com
'66 R60/2
'72 BMW 2002
Instagram - jj_withers
Re: Tuning Advice
Major Softie wrote:Was your typo meant to be ironic? :lol:
