(3) I wanted to see for myself if the Dellortos have any performance edge over the Bings. I've read about every thread posted about this conversion prior to setting out..........some folks reckon yes.....some reckon no.
Well, the conversion is complete and the bike is running well. After a weekend of gentle cruizing and a few hard runs, plug chops tell me that the motor doesn't seem to mind the change. There is one issue that I am uncomfortable with though and that is that I'm getting an inordinate amount of white/greyish smoke at idle. The smoke doesn't smell oilly and prior to the carb change the motor was smokeless; new guides, valves, good rings and bores, etc. Would the idle circuit be contributing here and would a change of jetting be required or just adjustment with the Idle mixture screw? I started with the 90S settings of 1-1.5 turns from seated and I've experimented with more turns out (leaning the mixture.yes?) but getting a balance between idle mixture and idle speed (I'm aiming at about 1100 rpm) and no smoke is tricky!!
I think I'll perservere.........The throttle response is really good
Any comments on the smoke issue? has anyone any similar experiences?? Thanks, Hools.
