1972 R60/5 engine related dimensions needed
StephenB
Post by StephenB »
I am building a 600cc engine from the ground up (to match my R60/5 frame). I hope somebody can get me some dimensions as the block came to me empty (as in no studs installed). I need the protruding length of the 3 timing chain cover studs and the cylinder head studs. I will use 1976-1984 rocker gear but that shouldn't matter for the length, should it?
I have never written down the Allen head bolt sequence, but I guess I can go by my own picture and figure it out:
Link to higher resolution:
http://www.stephenbottcher.net/BMW/R755 ... CF0044.JPG
Apparently two bolt sizes (M6x40 and M6x35) and the three long nuts. Is the 6x16 so-called anti rattle pin down in the bottom left really required?
Thanks in advance, Stephen
Re: 1972 R60/5 engine related dimensions needed
Tom Cutter provided this for the cylinder head studs on a /6...the /5 and /6 have the same stroke:
"9-7/8 (9.875") to 9-15/16 inches (9.9375") or (250.8-252.4 mm) from the case gasket surface to the end of the stud"
StephenB
Post by StephenB »
That's a start, thanks Kurt. I read the number 252 before just wasn't sure.
mattcfish
Post by mattcfish »
StephenB wrote:I am building a 600cc engine from the ground up (to match my R60/5 frame). I hope somebody can get me some dimensions as the block came to me empty (as in no studs installed). I need the protruding length of the 3 timing chain cover studs and the cylinder head studs. I will use 1976-1984 rocker gear but that shouldn't matter for the length, should it?
Just checked my 71 R60/5 block. The 3 timing cover studs protrude about 36mm (no gasket). I don't have the head studs installed.
StephenB
Post by StephenB »
Thanks, Matt.
