1972 R60/5 engine related dimensions needed
Posted: Sun Oct 09, 2011 7:35 am
I am building a 600cc engine from the ground up (to match my R60/5 frame). I hope somebody can get me some dimensions as the block came to me empty (as in no studs installed). I need the protruding length of the 3 timing chain cover studs and the cylinder head studs. I will use 1976-1984 rocker gear but that shouldn't matter for the length, should it?
I have never written down the Allen head bolt sequence, but I guess I can go by my own picture and figure it out:
Link to higher resolution:
http://www.stephenbottcher.net/BMW/R755 ... CF0044.JPG
Apparently two bolt sizes (M6x40 and M6x35) and the three long nuts. Is the 6x16 so-called anti rattle pin down in the bottom left really required?
Thanks in advance, Stephen
