Dead horn...
DanielMc
Dead horn...
Post by DanielMc »
I just picked up a really nice looking chrome centred Bosch horn that looks like it's never been used:
Problem is it doesn't work. No spark when I connect a battery and no sound whatsoever. I thought these things were a simple coil and therefore pretty foolproof, but I was clearly wrong. There's no way of opening the thing up and I've already played about with the screw (turned it in and out) to no effect.
Anyone ever fixed one of these?
Re: Dead horn...
What does the other side look like? Horns should work one of a couple of ways...power in one terminal, out another terminal to ground; or power in to one terminal and the mounting point becomes the ground path back to the battery.
DanielMc
Re: Dead horn...
Post by DanielMc »
Here's the back view:
There was a blob of sealant over the screw head that I removed...
George Ryals
Re: Dead horn...
Post by George Ryals »
Give it a whack with a broomstick. Maybe the points are stuck.
Re: Dead horn...
Put a multimeter across the terminals on the Ohms range. Should show a low resistance. If not try winding the screw in and out to see if it makes any difference. If you don't get any chage afert winding the screw in and out (fully) six or seven ti8mes, it's bound for the bin.
DanielMc
Re: Dead horn...
Post by DanielMc »
Big thanks to George and Rob!
Ran a multimeter across it to start and it read 1.00 which was bad. Then I hit it hard (not a broomstick, but the back of a wire brush) and turned the screw in and out six times and now the multimeter reads 0.01 which is good! After a bit of adjustment with the screw the horn is now sounding fine and ready to go on my restored '74 bike.
Whether it was the "percussive maintenance" or the screw or both I'll never know, but I am indebted to you for your help.
moonbeamerll
Re: Dead horn...
Post by moonbeamerll »
Re: Dead horn...
DanielMc wrote:"percussive maintenance"
Yep, yer can't beat it!
Re: Dead horn...
Post by Deleted User 62 »
Or yes, you can! :lol:
Re: Dead horn...
One of the many charms of wood is that it can be used to beat recalcitrant metal things into behaving properly. :geek:
