Page 1 of 3
/2 reverse conversion. Driveshaft fun
Posted: Sun Mar 18, 2012 8:56 am
by Izzypwc
Hey guys. Here's one for you whizz kids. I'm doing a reverse conversion project:
- /5 frame
- /5 SWB swingarm (I think here lies the problem):ear
- /6 final drive
- R50 engine
- /2 gearbox
There is a lot of information on this site about people putting /5 engines in /2 frames but hardly any info on these reverse conversions.
My question is simple: what is the simplest way to get the driveshaft to work with the earlier transmission. Firstly I think I might have "length" issues i.e.: it seems the driveshaft is a little long. Second, can I use a /5 output flange on the earlier gearbox (I believe both use a 1:6 taper) Am I better off using a LWB swingarm and perhaps the /2 driveshaft? Would the /2 shaft work with a /5 final drive?
So many questions too little gasoline.
Thanks guys
Darren
1962 Manx norton
1968 R50/2
1916 Harley Davidson J
Re: /2 reverse conversion. Driveshaft fun
Posted: Sun Mar 18, 2012 11:37 am
by Motorhead
One Fellow at the Griffth park had a custom /2 conversion
R90 motor to the /2 tranny with a /6 rear ger box?
so I asked how?
He said /2 drvie shaft and /6 cup and the rest was easy to "fit"
so as I think maybe you use the /2 drive shaft AND /6 cup
Posted: Sun Mar 18, 2012 11:57 pm
by Izzypwc
That won't work. I'm using a SWB swingarm...the /2 driveshaft would surely be too long...
Posted: Mon Mar 19, 2012 12:10 am
by Motorhead
Maybe he cut and welded the drive shaft or machined the attchment to use the cup
Posted: Mon Mar 19, 2012 1:34 am
by Deleted User 62
It might be easiest to move the engine mounts a bit further forward.
Posted: Mon Mar 19, 2012 5:42 pm
by George Ryals
Have you tried the /2 Conversion group on Yahoo? They may know all about it.
Posted: Mon Mar 19, 2012 6:27 pm
by mattcfish
Reverse conversion.....newer bike, old under powered motor, old tranny.........why?
Just Postulatin'
Posted: Mon Mar 19, 2012 7:26 pm
by Deleted User 62
Reverse conversion.....newer frame, older motor.........why:
Rennsport!!! Am I right?
Posted: Mon Mar 19, 2012 9:39 pm
I too was trying to figure out why.
Posted: Mon Mar 19, 2012 9:52 pm
by Izzypwc
Correct...rennsport replica in the making! I have a great hose tank and killer seat to match. Just need some help on the driveline. Thanks guys.
