/5 3.5A current draw
x1Buellist
I received the battery cables from Euro MotoElectrics. Hooked them up. My bike is drawing 3.5A with the key inserted. Is that right?
73' R75/5 LWB
Re: /5 3.5A current draw
Sounds about right
2 to 3 amps for coils and a little more for the idot lights
x1Buellist
Thanks. I will put the headlight enclosure back together. It's time to go buy some gas.
73' R75/5 LWB
Far more important to measure the very small draw with all turned off. Should be well below a miliamp unless you have things that run all of the time, such as a clock.
Ater the ride lets see some Pix then we can see the final and toast your success
