I remember working with sheet metal in Jr. High. We used fairly heavy tin (I think) and worked with a brake and learned how to do the necessary tricks to make a box, or something (a long time ago.). And whatever the base metal was, we also learned soldering using flux and an iron. No flame. So no - we were not brazing.
Which brings me to my questions.
Will I need a small brake to duplicate something like this? Or will a pair of locking metal-working pliers be good enough?
I've no idea what metals are available easily and economically but will hold up to a hostile environment.
And I think I will need to learn to braze (just because I have heard it referred to so much here, and from what I've read on the subject, it seems to be a possibility) to create a leak-free box.
I thought about putting some scrubbing pad inside to catch some of the oil. Maybe a drain plug on the bottom?
I can see the main breather entering the box on the left, and the vent tube on the right - but I think I see another tube entering the box in between the two. ?
I wonder what it could be?
