Tank Badge Removal
Posted: Sun Jul 29, 2012 1:10 am
by Bob Bennett
G'day Fellars
I'm a bit apprehensive about getting these buggered badges removed from the tank without damaging it any further,
It's not perfect but it does me, so does anyone know a way to do this with no dings or scratches?
Thanks in advance.
Re: Tank Badge Removal
Posted: Sun Jul 29, 2012 2:04 am
by dwerbil
Bob, try using a hair dryer. A bit of heat and the adhesive should come right off.
Posted: Sun Jul 29, 2012 2:45 am
by Bob Bennett
That sounds good, I'll try it out, thanks heaps dwerbil.
Posted: Sun Jul 29, 2012 2:49 am
The hairdryer heat + cutting through the adhesive with some dental floss will even get a stubborn one off.
Posted: Sun Jul 29, 2012 5:44 am
Major Softie wrote:The hairdryer heat + cutting through the adhesive with some dental floss will even get a stubborn one off.
That's the one.
Posted: Sun Jul 29, 2012 7:01 am
by sterob
You want to preserve that badge?
Jeez, Bob, they are not that expensive. Your bike will look a million dollars with new ones.
Posted: Sun Jul 29, 2012 11:21 am
by Deleted User 62
If you want to get the new badges correctly aligned, put a piece of tape over it with one edge lined up with the horizontal line of the blue / white and overlapping on to the tank. Cut the edge where it leaves the emblem, then you have a way to line it up.
Posted: Sun Jul 29, 2012 12:22 pm
by montmil
Tim Shepherd wrote:If you want to get the new badges correctly aligned, put a piece of tape over it with one edge lined up with the horizontal line of the blue / white and overlapping on to the tank. Cut the edge where it leaves the emblem, then you have a way to line it up.
This little tip is golden.
