What's inside my 81 beancan?
Don't say beans, that's something Me would say. :roll:
I don't believe that I've seen a post on servicing an electronic beancan.
At nearly 31 years old, surely there must be something in there that I can mess with?
Advance weights?
I could go and just open mine up, but asking first seems a better idea.
Anyone got any photos?
Thanks.
Re: What's inside my 81 beancan?
Ah now Jeff, be careful. There's a special BMW tool involved -
ps: I know you'd be disappointed if somebody didn't take a shot.
Post by Deleted User 287 »
Lubricating the advance weights is always a good idea.
You can replace the weight springs - Motobins has them: Part No.72620.
Rob Frankham used to have an article on his website for a Hall Effect beancan overhaul, but his site seems to be suffering some sort of (probably Olympic-related) illness. http://robfrankham.co.uk/bike/replacing ... sensor.htm
Here is a good thread on doing a points beancan: http://www.advrider.com/forums/showthread.php?t=394966
There is an inspection port on the side of the can at weights-level, but it is impossible to do anything really important through there.
Last edited by Deleted User 287 on Wed Aug 08, 2012 5:23 am, edited 1 time in total.
Airbear wrote:ps: I know you'd be disappointed if somebody didn't take a shot.
:P
Thanks Charlie.
After all I've given, it's nice to get a little back.
Here is another article you might enjoy (no photos).
http://bmwscotter.org/topics/common_mod ... update.htm
Embedded in that article was this one by David Braun: http://maniac.deathstar.org/~flash/ig_trig.html
BTW - buy a copy of David's book Gathering Speed, it is a great collection of short (mostly true, I assume) stories:
http://www.deathstar.org/~flash/
Thanks Rob, that thread gives an indication of what's in there.
I have a spare that I can swap to see if there is any difference..
The one presently on my bike is giving no trouble that I'm aware of, but it would be nice to know that I'm getting every ounce outa the ol' gal.
I replaced the springs (Motobins) in both of mine (bike + spare) and cleaned and lubed the advance weights.
It can be done either by disassembly or through the little window. I have done both.
Deleted User 72
Post by Deleted User 72 »
I made this tool from a strip of aluminum to pull the points plate out of the can. I put a 1" pipe through the loop and suspended it from a vice, then just tapped the edge of the can with a leather mallet. Its much easier to get the inside of the can nice and clean with the points plate out of the way.
Native /5 wrote:I made this tool from a strip of aluminum to pull the points plate out of the can. I put a 1" pipe through the loop and suspended it from a vice, then just tapped the edge of the can with a leather mallet. Its much easier to get the inside of the can nice and clean with the points plate out of the way.
NICE!Image
Thanks chaps, I might start by pulling the spare unit apart and having a looky see.
