4 inch diameter and only 1 inch thick. GPS accuracy, no need for a pick-up. The inset tacho is icing on the cake.
Really? I figured the /5 instruments were bigger than that. 85mm is the stock size for my /7 speedo and tach.Airbear wrote:Very nice instrument, Mal - I want one.
Consider the 3 and 3/8 inch version - it'll fit into a slash five headlight bucket (85mm hole) if you happen to find one.
Hmm, you've got me doubting now. My chinese copy has an 85mm hole. Timo will know.Mal S7 wrote: Really? I figured the /5 instruments were bigger than that. 85mm is the stock size for my /7 speedo and tach.
Good question, and I was about to say that I like the Vapor better for that reason alone, not to mention it's other features, like ambient temp. and clock.Ross wrote:Will it keep working when you go through a long tunnel or a underground carpark?
