77 R100s Clock Quit
00_Green
77 R100s Clock Quit
Post by 00_Green »
After 33 years my clock quit. :shock: It stripped a gear from the looks of it. I know I could have it rebuilt but I'm more interested in cheaper or other options. I'll box this one up and put it away if I can come up with an alternative.
What have you guys used to replace your clocks or do you just leave it in the dash inop?
Thanks!
00_Green
Re: 77 R100s Clock Quit
Post by 00_Green »
Yeah it's my first post, my name is Dave, I live in Ga. Here's my bike ........................ :D
The link didn't work, I'll try again later.
How about a Hobbs Meter?? ;)
Welcome Dave.
Google VDO 50mm clock.
Schnell
Post by Schnell »
I have a similar problem on my RS and am to cheep to have it fixed. I found OEM units on ebay but were also pricey. I did find suitable replacements when searching marine applications. D*#n if I can remember the manufacturers name though.
Not again !!!!!!
Nathan's swap meet is THIS weekend, Nov 6.
Blue Moon 9Norcross) is next weekend, Nov 13.
Maybe you can get a salvage clock at one of these.
Can the clocks be maintained to avoid failure? :)
Zombie Master wrote:Can the clocks be maintained to avoid failure? :)
Keep the valves set and change the oil regularly.
Sooo, would you run dyno or synthetic oil in your clock. Can you get REAL synthetic oil for your clock anymore? :?
moore84rs
Post by moore84rs »
I had mine repaired by these guys. I can't remember the cost.
http://www.paspeedo.com/bmwclocks.htm
I don't know if this company makes clocks, but when the voltmeter failed in our R100RS (really a dressed S) I found a good replacement that WORKS, from EQUUS. at an auto part shop. It was about $18, and fit the hole in the dash nicely. Looks good too.
You might try for something like that.
Unless you have a burr in your britches about this "original" stuff....
