Posts: 5036 Joined: Tue Aug 03, 2010 3:29 am
Post
by SteveD » Fri Jun 12, 2015 9:56 am
I've got one. It's a cheap second hand one, but it's great to have.
It goes up ok. It doesn't want to come down as it should.
It looks very similar if not an older version of this...http://www.ebay.com.au/itm/360KG-AIR-or ... 4d32866724
It has a foot lever to pump it up and a smaller foot press to release it. The linkages seem a little loose and I usually wriggle them about and it'll eventually drop.
Any ideas on how I might fix this thang?
Posts: 8828 Joined: Sun Aug 22, 2010 12:21 am
Post
by Zombie Master » Tue Jun 16, 2015 10:43 pm
Did you check to see if it has adequate fluid?
Post
by SteveD » Wed Jun 17, 2015 4:53 am
It goes up ok and stays there. No leaks I can see. It's the release that doesn't work properly. I'm told there's a ball valve in there that might not be getting enough push. The linkage is loose. It's a w/e fix this w/e.
Posts: 7313 Joined: Tue Aug 03, 2010 3:00 am
Post
by ME 109 » Wed Jun 17, 2015 9:17 am
Where's your RS?
Post
by SteveD » Wed Jun 17, 2015 9:49 am
I got it down by hitting the linkage carefully with a broom stick, whilst keeping my foot on the lever. It came down very slowly, but it came down!
Post
by SteveD » Fri Jun 19, 2015 12:16 am
Fixed! The lock nut on the foot lever was loose so that the lever was too loose. It took longer to get it out and check it over than it did to fix!
Posts: 6008 Joined: Thu Aug 12, 2010 12:39 pm
Post
by Duane Ausherman » Tue Jun 23, 2015 4:13 pm
I see that the Harbor Freight lift is about $400 now. A friend wants to buy one. How does he do better?
Bamboo812
Posts: 1451 Joined: Mon Jan 06, 2014 4:45 pm
Post
by Bamboo812 » Tue Jun 23, 2015 5:03 pm
Tell him to apply this code when checking out: 29915397 (I just tried and the price went down to $329)
Post
by Zombie Master » Tue Jun 23, 2015 10:25 pm
Duane Ausherman wrote: I see that the Harbor Freight lift is about $400 now. A friend wants to buy one. How does he do better?
Pay less. I paid $200. The lifts are fine for bikes up to 600 pds IMO. But who would want a bike heavier than that? I wouldn't buy one for a commercial shop though.
