Replacing large left seal in rear drive, '81 R100
itsme
Post by itsme »
To replace the seal, does the cover need to come off? Any special tricks? Regular tools sufficient?
Bamboo812
Re: Replacing large left seal in rear drive, '81 R100
Post by Bamboo812 »
Wrap the splines with electrical tape or similar to avoid damaging the new seal when installing.
itsme
Post by itsme »
Bamboo812 wrote:Wrap the splines with electrical tape or similar to avoid damaging the new seal when installing.
Great idea, thanks!
itsme
Post by itsme »
old seal is out, need to clean now.
mattcfish
Post by mattcfish »
A Ranier beer can with the ends cut off fits perfectly over the splines too.
You should remove the cover and replace the gasket. It comes off easily...you thread in 2 screws to pull it off, there are threaded holes provided for this purpose.
montmil
Post by montmil »
mattcfish wrote:A Ranier beer can with the ends cut off fits perfectly over the splines too.
Most first-timers miss the two threaded holes that assist in removing the Cardan cover. 5mm, IIRC.
I've successfully used a trimmed aluminum adult barley beverage can as a seal/spline install tool. The rounded punt/bottom of the can gets the seal's lip properly positioned. Be sure to smooth the cut edge of the can as even a small burr can ruin the seal's fragile lip as you remove the "special tool". Plus, oil to can to aid in a smoother install.
That and don't forget the gasket!
Monte
1981 R65
1983 R65
1978 R100S
1995 Triumph Trophy
Bamboo812
Post by Bamboo812 »
Modern cardan gaskets are thicker now than the original paper thin ones. Replacing it will most likely require re-shimming.
Bamboo812 wrote:Modern cardan gaskets are thicker now than the original paper thin ones. Replacing it will most likely require re-shimming.
Is a modern gasket in a tube out of the question?
https://www.threebond.co.jp/en/technica ... skets.html
Bamboo812
Post by Bamboo812 »
Not out of the question; paper gaskets went the way of sword fighting awhile back. In this case though, taking either new or old gasket out of the question still requires re-shimming...
enigmaT120
Post by enigmaT120 »
Bummer. I'm really good at sword fighting.
But I can't make paper gaskets seal.
Ed Miller
'81 R65
'70 Bonneville
Falls City, OR
