Closing Speedo Cable Hole
0m3nc0w
Post by 0m3nc0w »
Has anyone replaced a speedo with an aftermarket and needed to plug the threaded cable receiving port?
My local BMW dealer has told me there is no solution they can offer me.
If anyone has any idea how to go about this I'd appreciate a link or suggestions, it isn't as easy as just finding a proper size bolt to fit the hole due to the way the side bolt interfaces with the main speedo port shaft.
enigmaT120
Re: Closing Speedo Cable Hole
Post by enigmaT120 »
Justin over on R65.org sold me mine. It just looks like a flat button from the top.
Ed Miller
'81 R65
'70 Bonneville
Falls City, OR
montmil
Post by montmil »
Cheap arse Airhead owner I know quite well uses tapered rubber plugs sourced from Ace Hdwr & Airhead Sply. They work on both of my... oops... that guys bikes.
1981 R65
1983 R65
1978 R100S
1995 Triumph Trophy
I know of an even cheaper-arsed airhead owner who uses a bit of fuel hose wedged in with an ebony violin tuning peg ...
... and apparently there are other places on my this guy's bike where violin pegs have been utilised ...
sprints@pldi.net
Post by sprints@pldi.net »
Just happen to be doing that to mine right now. I removed the drive worm and am machining a nice aluminum flat top plug to fit. I will probably use a fiber washer or o-ring for a seal and I'm modifying a stainless bolt with a vent hole - someone tapped mine for 1/4-20.
Be glad to make 2 if you want one.
I'll need your shipping / mailing info of where to send it - Rod
enigmaT120
That guy must have really hated his kids' violin practice.
Ed Miller
'81 R65
'70 Bonneville
Falls City, OR
Ken in Oklahoma
Post by Ken in Oklahoma »
Airbear wrote:I know of an even cheaper-arsed airhead owner who uses a bit of fuel hose wedged in with an ebony violin tuning peg ...
Cool! I presume the violin tuning peg is made of ebony. A bit of warning to others though, use of an ivory tuning peg will betray you as a (deleted).
