nearly ready to get my refurbished r100rs on the road again,,but the brake light doesn't come on when the rear brake is used ,,the front brake lights up fine,,
I cant figure out how the Norris switch is removed,,does it have two screws holding it?
could this be the problem
look forward to some advice and inspiration
regards tony
rear brake- light not activating
Re: rear brake- light not activating
Spray the switch with electrical cleaner...jiggle it...spray it again. They get gunked up and usually just need a clean.
Boronia, Vic, Oz?
Boronia, Vic, Oz?
Two screws under the rubber cap on top of the switch.
Check the brake pedal is contacting the front of the switch.
Check you have power to the switch. Check you have power to the brake light bulb socket, when activating the brake pedal.
I'm in boronia vic aus
Had this issue on my 1978 R100S. The rear brake light would work only occasionally. Checked proper operation and brake pedal contact, power to the tail lamp, bulb function. Hosed it with electronic parts cleaner spray, burned incense, chanted...
Bought new switch. It's all good.
1981 R65
1983 R65
1978 R100S
1995 Triumph Trophy
1983 R65
1978 R100S
1995 Triumph Trophy
thanks blokes ,ive got that little sucker sorted,twas the Norris switch-loose connection,,a bugger to get at ,but I'm nearly finished my bike now
thanks all
thanks all
Pix or it didn't happen!
I'm in Croydon.
My 1979 R100Rs, cant align rear brake pedal with the switch activator, so brake light stays on always, is there any way to adjust the brake pedal mechanism ? The switch has a fixed bracket , no adjustment
Willcommen eriojas. Have you got all the spacers/fasteners? And in the correct location?
Willcommen eriojas. Have you got all the spacers/fasteners? And in the correct location?SteveD wrote: ↑Fri Apr 04, 2025 10:20 pm [quote=eriojas post_id=136578 time=<a href="tel:1743818166">1743818166</a> user_id=13390]
[/quote]
- IMG_2157.jpeg (1.66 MiB) Viewed 4289 times
