Clutch Plate / Slip Disc
neonwall
Post by neonwall »
Fairly simple Q here however Im don't have a manual and wanting to reinstall clutch on R80 RT 1986. What is the correct orientation of the Slip Disc and what is the correct torque for clutch Bolts?
A couple of images I found are contradictory as attached. Any help appreciated
Clutch Plate 2.jpg (114.97 KiB) Viewed 3055 times
1986 BMW R80RT
neonwall
Re: Clutch Plate / Slip Disc
Post by neonwall »
By orientation I mean which side faces out?
1986 BMW R80RT
Bottom pic is correct.
Aha! I could only see one image previously but now I see that you are referring to the friction disk.
The longer spigot points towards the gearbox. Here you go:
From Max BMW parts fiche.
Do you not have a workshop manual? The Clymer manual is a really useful investment, with good step-by-step pictorial guides to almost every procedure and it has all the torque settings and tolerance limits you could ever need:
https://www.amazon.com/Clymer-Repair-Ma ... B000GZX312
neonwall
Post by neonwall »
Excellent thanks guys, yeah i do have a manual however it is the BMW service manual and not as detailed. 20Nm torque on the Clutch bolts yeah?
Thanks again
1986 BMW R80RT
What's a Nm? :lol: But yes, something like 15 ft-lbs is right.
dougie
Post by dougie »
Kurt in S.A. wrote: Tue Jun 26, 2018 4:49 pm What's a Nm?
That's how hard Newton kicked that phucking apple that hit him on the head. :idea:
You know, Nm Nm Nm Nm Nm. :geek:
ZM will be along shortly.
Wobbly
Post by Wobbly »
Kurt in S.A. wrote: Tue Jun 26, 2018 4:49 pm What's a Nm? :lol: But yes, something like 15 ft-lbs is right.
There are lots of metric conversion web sites available to help determine exact equivalents. Where a torque is given, it's best to assume that trouble will follow if not closely adhered to. I've been using this site for about 15 years....
http://www.onlineconversion.com/
Scroll down the first page until you get to Torque and there will be all the conversions you'd ever need.
Wobbly -
I was just joshing about Nm...actually that is the site I go to a lot to make my conversions. My memory says that 1 Nm is about 0.7 ft-lbs.
