So next was setting up the throttle cables and the fuel system. I installed the tank and got a couple gallons of ethanol-free and felt hopeful.
NANANANANA pop pop NANA pop NANANANANANA pop. But not quite enough to keep going when I took my thumb off the button.
So I checked all four plug wires with a spare plug to see if I had spark all around. Top left seemed to be without spark, so I checked at the coil. This was the result:
Humph! Aftermarket coils with an odd connection scheme. I slept on it and went to the local auto parts store this morning. To his credit, he didn't ask what it was from and just grabbed the coil and the bits and went to the back room. 10 minutes later, he came back. "Nope. What's it from?" "It's an aftermarket coil on an old BMW motorcycle." The coils smell Japanese. As it turns out, they were 12V and wired in parallel.
When I got home, I took the other coil off and found more troubles:
I'm kinda unwilling to spend too much money on this one, so I dug through my stuff and found the old coils from Ernst and set things up with just the top plugs hooked up, and 6V coils wired in series. Then with a good hot charge on the battery I took another stab at the starting it up. NANANANANA pop pop NANA pop NANANANANANA pop. But not quite enough to keep going when I took my thumb off the button. Humph!
Maybe to get a bit more juice to the starter, I took off the supplemental taillights. Here's how they were wired in to the existing taillight:
OMG! More posilocks! AND A WIRE NUT! I cut the wires off and removed the license plate frame which, as it turns out, was what held the additional lights:
Another go at it. NANANANANA pop pop NANA pop NANANANANANA pop. But not quite enough to keep going when I took my thumb off the button. Humph!
I did a quick run through the carburetors to make sure I had the chokes on the correct sides and that the chokes and pilot jets could pass fuel. Once more: NANANANANA pop pop NANA pop NANANANANANA pop. But not quite enough to keep going when I took my thumb off the button. Humph!
I talked my son into pushing the bike half a block up the hill to see if we could bump start it. I can bump start Ernst all by myself on the flat, so I didn't think there'd be much to it. RUN RUN PUSH PUSH into second gear clutch out SKID. Humph!
Imma think about this overnight. I will say that there was enough pop in the NANANANA that the headers warmed up a bit. So close!
