1982 R100RT Replacing Headlight with LED
gsm_r100rt
Post by gsm_r100rt »
While searching internet for H4 LED bulbs most of the information was that the OEM housing was not designed to correctly focus the light emitted by the LED's.
Then I found this product.
https://www.summitracing.com/parts/sum- ... 8kQAvD_BwE
It has a glass lens and DOT approved.
Not affiliated at all with summit racing
Think this would fit in the R100RT headlight bucket?
Re: 1982 R100RT Replacing Headlight with LED
Not really, Most airheads, Road models anyway, take a ten inch reflector. This on is only seven inches. I suppose it would be possible to arrange some sort of surround to take up the extra space but it certainly isn't plug and play.
Rob Frankham wrote: Fri Aug 15, 2025 5:20 am Most airheads, Road models anyway, take a ten inch reflector.
10 inch reflector !!!! ????? hmmm
gspd wrote: Fri Aug 15, 2025 2:17 pm
Hmm, I'll have to go and measure one... but I'm sure it's not 7" so the rest of the comment applies...
8" except for R45/65's which are smaller
Tom H Ca
Post by Tom H Ca »
My '73 R75/5's are aprox. 6 1/2". I even matched them up to a 7" and they are smaller.
Tom
'73 R75/5 SWB
'73 R75/5 LWB
'70 Guzzi Ambo 750
'72 Guzzi Eldo 850
'04 Guzzi California EVT
'07 HD Dyna Street Bob
Tom
Tom H Ca wrote: Sat Aug 16, 2025 9:20 am My '73 R75/5's are aprox. 6 1/2". I even matched them up to a 7" and they are smaller.
Tom
Same size as the R65 headlamp which can be used to upgrade a/5 to a H4 halogen bulb.
barryh wrote: Sat Aug 16, 2025 5:47 am 8" except for R45/65's which are smaller
Absolutely right 8 inch by the tape measure. Apologies, my memory ain't what it used to be... but a 7inch reflector still won't fit...
Jeff in W.C.
Post by Jeff in W.C. »
If you're looking to upgrade your headlight to LED, here's an option. It's a smaller headlamp with an adaptor ring. I have not installed one, so I can't comment on the product other than it exists. http://www.motoelekt.com/lighting.htm
Jeff in W.C.
1988 R100 RT
2018 R1200 GS
