10 years later........
Re: 10 years later........
Like the leading link forks using the bikes sliders, neat.
Arado Ar234
Managed to find a locksmith to cut a key, as I can take the whole tank in to him. Saves destroying the cap drilling it out. Of course, I'll never lock it again. The other question is cleaning out the inside of the tank.....does anyone have any idea how to clean all the scale and crap out of it without costing a million dollars, or damaging it. . Never had to do it before....
Here's Snowbum's page on tank cleaning:
https://bmwmotorcycletech.info/fuelmiscl.htm
Probably will need to reseal it??
Arado Ar234
Thanks Kurt...Snowbum really gets into the absolute molecular level of everything about BM's, and is probably the most knowledgeable person out there. Currently uncovering lots of boxed up spares as I continue to chip away at the project. .....
Arado Ar234
Just to put it out there...sidecar use is really hard on rear wheel bearings on the twin shock bikes. The hub on a cast snowflake wheel is as sloppy as, so I was wondering if anyone had any thoughts of supporting the tapered roller bearing cup using Devcon. Currently, the cup just falls out....
Yes, I've used the Loctite Sleeve Retainer in an application like that. It works best when it's a press fit that has deteriorated to a slip fit. It may not work if the slip fit has become a rattle fit.
Bill Smith
The best penetrating oil I've found is a 50/50 mixture of automatic transmission fluid and acetone. It beats anything I've bought commercially.Arado Ar234 wrote: ↑Sat Jan 17, 2026 4:43 pm So, as you can see, it is rather modified, and somewhat mouldy after 10 Tasmanian winters, which last for 11 months of the year. I have a myriad of spares for this one, including 3 gearboxes, barrels, pistons, heads, carbies etc. Currently using the rear swing arm and final drive from a 75/7 as the sidecar wheel and suspension system. That rust welded fuel cap is the only thing that is really concerning me right now......can't apply heat obviously, although it would be spectacular to watch from a distance. Thinking about turning the tank upside down and pouring penetrating oil into it once I remove the fuel taps. If anyone has another idea, I'd be happy to hear it.
Arado Ar234
Thanks for the penetrating oil advice. Got it to free up, so will take the whole tank to a locksmith and get a key cut. The bearing cup will definitely need building up, and i have used shims and loctite in the past, so I'll give the Devcon a go. I'll talk to a machinist first, as , of course, the wheel hub is alloy, and the cup steel. Side car stresses are hard on 70's BM's rear wheels. With so many times around the clock, the bearing surfaces and wheels themselves cop a hammering. Aside from that, I have found so many spare parts, many new or reconditioned, that have been packed away since last century. I picked up lots of spares from lots of sources....complete bottom ends still in the block, heads, barrels, rockers etc. At least 3 complete starter motors, plus parts , numerous charging system components, two complete gearboxes, and two disassembled etc etc. In for some late nights sorting and itemising. At least I'm making progress.......
Arado Ar234
Repeating myself a bit......lots going on, so don't always back track to check what i have already said, and make sure i don't sound demented....
