The lower position makes the metal part of the footpeg touch the frame, you can see where it's rubbed in the picture/
The higher position seams too high in regard to the brake lever and too close to the carb., that's where it's set in the picture.
The higher position seams to make it just slightly higher than the left side (which is adjusted to make shifting work best for me).
The other issue when I look at it, my brake pedal is alread set with the bolt set like this..
Which Duanne says in incorrect. If I set it "correctly" the pedal will be even lower.
But if I use the higher footpeg location, I'd want to raise the break pedal even more than it is.
Does anyone else's left peg touch the frame or is it set in the higher spot? Any lower and it would hit the exhaust.
