It looks just like the Omega but the "black box" processing unit is bigger and beefier. They are avilable for 216 EU (no VAT) + ship from Ulis Motorradladen. See Stephen B's link in his earlier post..I bought for $150 CDN used.
Plan on installing this week and see how it goes. Well, at least I will be firing up engine but clutch and tranny are out right now so won't be going anywhere with it. All instructions in German but able to cobble up translation from my wife, a neighbour and google. Little sketchy on setting adnace degree but guess that will be trial and error.
Been redoing a 78 R100/7 which has a pretty knackered points system so was going to install this unit to get it up and running.
Will see how it goes and if OK I really want to mount on my 77RS.
Idea of maybe mounting processing block outside front cover for cooling etc I might try. Don't think where located should be an issue to functionality but would have to be weather protected. I'll maybe mount first under front cover then try mounting point (weather protected) under the gas tank somewhere? Would involve splicing in longer wire leads between pick up unit and processor. Would run length of wires affect functionality? Maybe go with one size bigger wire in longer run so no slow down in electrons? Don't know but any electronic gurus out there give me some advice...
