I would not think that the orientation of the spring matters ...
Certainly less so than verifying it's compression rate ...
I just removed my first valve spring!
Re: I just removed my first valve spring!
Other than possibly suffering some damage in the crash, the springs were relatively brand new, having been replaced by Bob Grauer when he refurbished the heads in the fall of 2006. The crash was two years later, in 2008.vanzen@rockerboxer.com wrote:I would not think that the orientation of the spring matters ...
In fact Bob replaced valves, seats, springs and collets. Everything except the top and bottom spring plates, if I remember correctly.
I really feel bad about destroying half of Bob's artwork with my inattentiveness.
My finger hurts sometimes, too.
lapping valves ...
Don't feel bad, Rob ... Sh!t happens, move forward.
Same valve, same head & seat, but different spring ?
or different valve on the seat ?
Re: lapping valves ...
I am going to install the springs (and possibly collets, tops and bottoms - depending on rust) from Bob G's work onto my new used engine that has rusted internals.vanzen@rockerboxer.com wrote:
The old engine was a '80, the new engine is a '81.
The differences are Nikasil cylinders and different sized valves, so I have to keep the valves that are on the marginal engine.
I have already rejetted the Bings to '81 spec., and pretty successfully (for a first time), if I dare say it. My run to Columbus, OH and back last May showed normal power and fuel consumption.
The part #s on everything except the valves themselves were unchanged from '78 - '84 on the Type 248 engine:
http://www.realoem.com/bmw/partxref.do? ... series=248
You may have missed my original thread on this, started last Sunday afternoon:
http://www.boxerworks.com/forum2/viewto ... f=1&t=2924
Rob, I look forward to some 'out there and riding' posts from you.
It's been a while man!
My plates expire 15 Oct....ME 109 wrote:Rob, I look forward to some 'out there and riding' posts from you.
justoneoftheguys wrote: My plates expire 15 Oct....
Hmmm ... mine, too.
You will surely have this beast back together by Oct 15. Hopefully by Sept 1...
It's time to start another post: "I just got all the valve springs re-installed" !
And I'm betting it is NOT a good idea to reuse head gaskets.Jean wrote:You will surely have this beast back together by Oct 15. Hopefully by Sept 1...
I neglected to include them in my order for o-rings - not that I can afford to be throwing another $33 +shipping at this project while unemployed.
Not necessarily recommending this, but I used it once on an air-cooled engine and it worked.justoneoftheguys wrote:And I'm betting it is NOT a good idea to reuse head gaskets.
I guess it would depend on how good/bad you gaskets are.
http://www.permatex.com/products/Automo ... ealant.htm
