tubeless
twist
Re: tubeless
Post by twist »
nice! I like the idea of using the engine for compressor. Good to know about the stems, I could barely find the straight ones, (maybe because I live in SF). :roll:
I'm off to do the tire thing and install my new, (to me), wheels. This will be fun!
Jean
Re: tubeless
Post by Jean »
Engineair compressor...just be sure your engine runs OK on only one cyl. and remember to protect your electronic ignition if that's how you make a spark.
As in: Practice using it in your driveway. NOT on the roadside!!
twist
Re: tubeless
Post by twist »
Jean wrote:Engineair compressor...just be sure your engine runs OK on only one cyl. and remember to protect your electronic ignition if that's how you make a spark.
now, why didn't I think of that? :)
Re: tubeless
vanzen@rockerboxer.com wrote: I always carried an "engineair power pump" with my tire-plug kit.
I've got one of those too, but it's not so practical with my newer fuel injected bikes. :roll:
twist
Re: tubeless
Post by twist »
I have the new wheels installed with my new tires. Installed new front disc and brakes at the same time. I took my time and enjoyed the process, everything went swell. Now to break in a new rotor and breaks with new tires. Working on the bikes is part of the experience for me. The two go hand in hand for me and I feel satisfaction with the upgrade/retrofit.
vanzen
Re: tubeless
Post by vanzen »
Jeopardy time: Why were mini compressors invented ?
vanzen
Re: tubeless
Post by vanzen »
An airhead will run down the road on one cylinder,
provided no broken bits are in there to confound the revolution ...
Jean wrote:and remember to protect your electronic ignition if that's how you make a spark.
Simply lay the connected plug on a cylinder and you're good to go.
Re: tubeless
I think his real point was that your engine be in proper tune so that it will idle on one cylinder.
Sunbeem
Re: tubeless
Post by Sunbeem »
A very instructive thread, with a happy ending -- thanks Twist.
Nice to know your potential runner is now a potential non-runner.
Sunbeem.
One day more -- one day less.
Re: tubeless
Fish tanks and trials bikes?
