Ritmo Sereno R100RS
Deleted User 287
Re: Ritmo Sereno R100RS
Post by Deleted User 287 »
Jeff in W.C. wrote:Here's more on the bike
http://www.bikeexif.com/ritmo-sereno
Bikeexif wrote:Ritmo’s first objective with its ‘RSR‘ was to reduce the weight down to 190 kg—a substantial drop from BMW’s claimed dry weight of 242 kg.
You cannot argue that with all of the effort to remove weight during the build, that using lowers with holes for crash bars would be in line with that goal.
Jeff in W.C.
Post by Jeff in W.C. »
Yes using the lowers with the holes for the crash bars are more in line with that goal. I can't imagine that would lower the weight that much, but they would be lower in weight.
Jeff in W.C.
1988 R100 RT
2018 R1200 GS
justoneoftheguys wrote: You cannot argue that with all of the effort to remove weight during the build, that using lowers with holes for crash bars would be in line with that goal.
Clearly not enough effort to remove weight, or it was not a consideration.
How does one explain the centre stand, if weight reduction was important?
Jeff in W.C.
or better yet a center stand AND sidestand. They clearly could have removed one.
Jeff in W.C.
1988 R100 RT
2018 R1200 GS
robert
Post by robert »
Fairing can be duplicated in fiberglass cloth rather than the heavy and brittle stock cast resin/crap. The gas tank could be made of aluminum rather than steel for a great weight saving. It is a nice looking machine.
vanzen
coulda, woulda, shoulda ...
Post by vanzen »
The amenities of stands, lights, turn indicators, mirrors, plates, and etc
would be superfluous on a track bike,
and there will be no doubt that the Ritmo RSR could be trimmed further if this would be the case.
It is not.
Ritmo Sereno's design objectives were clearly stated from the onset:
"Ritmo’s first objective with its ‘RSR‘ was to reduce the weight down to 190 kg"
~ Bikeexif
... So do bear in mind that the RSR IS obviously, and certainly was designed to be –
a street machine !
And assuming that Ritmo's existing changes satisfied the proposed weight reduction goal ...
Why eliminate more ?
The modified RS upper-fairing appears to have been accomplished in carbon fiber ...
(although my reading of japanese text cannot confirm this purely visual assumption)
... a little CF should also have been used to patch the damn crash-bar reliefs in the lower panels, IMNSHO.
vanzen
Post by vanzen »
Nice pipes, too:
Deleted User 287
vanzen@rockerboxer.com wrote:Nice pipes, too:
Do you think he has to remove the whole shootin' match to drain the oil(s)?
vanzen
Post by vanzen »
justoneoftheguys wrote:Do you think he has to remove the whole shootin' match to drain the oil(s)?
Guessing, but just as the RB Racing "Black Hole" header of very similar design,
I'd put my money on a merge-collector that is offset slightly to allow drain-plug access.
